Unable to make calls
Shin
Hi everyone,
Since the 16 update we are unable to make calls using the android client.
Once we enter an extension/number and tap call. The phone switches to the android "phone" application and calls a random 5 digit phone number, which obviously doesn't do anything.
This happens on all smartphones. I myself have a Huawei Mate Lite 10.
Thanks for the advice.
Additonal Info:
Phone Model: Huawei Mate Lite 10 (My device, but same on all my collegues' devices)
Version: Android 8.0.0 // EMUI 8.0.0 // Kernel 4.4.23+ // Custom: CUSTC432D1
Handset: Smartphone
Connection: Both wifi and 4g give the issues
Server: Cloudhosted 3cx
Hi Shin,
Under Advanced, look at the Car/Bluetooth Support option and toggle it.
The kill the app the and restart your phone and try again.
Hi JohnS,
Thank you for the reply! Disabling the car/bluetooth support "fixes" the issues. But once I enable it again the issue returns.
Leave it disabled for now please, you should still have full functionality including bluetooth support without it.
I shall leave it disabled then! Thank you for the support!
Feel free to close or handle this thread as you see fit. My issue is resolved.
Mahlon
