Update from 18 update 9 (31) to 20 Failed
Sergey Yezhov
we want to upgrade our on-premise server to 20 version, but there is some troubles (Err:5 http://repo.3cx.com/debian/1809 bullseye Release
404 Not Found [IP: 172.64.147.129 80]) , please help if you can, there is log which i recieve on mail as error of update:
Code:
--2024-05-21 17:08:12--  https://downloads.3cx.com/downloads/misc/debian10to12/update.sh
Resolving downloads.3cx.com (downloads.3cx.com)... 172.64.147.129, 104.18.40.127, 2606:4700:4400::ac40:9381, ...
Connecting to downloads.3cx.com (downloads.3cx.com)|172.64.147.129|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 47260 (46K) [application/x-sh]
Saving to: ‘/tmp/update.sh’
     0K .......... .......... .......... .......... ......    100% 2.52M=0.02s
2024-05-21 17:08:16 (2.52 MB/s) - ‘/tmp/update.sh’ saved [47260/47260]
[33m====== [17:08:18] Preparation: Script path is /tmp/update.sh[39m
[33m====== [17:08:19] Starting: Backup script /tmp/update.sh[39m
[33m====== [17:08:19] Starting: Backup script version: 6129c6b15db886fbb9f9f47a58e7a046225005720255f565080145f34d802b33[39m
[33m====== [17:08:19] Starting: Current directory: /tmp[39m
[33m====== [17:08:19] Starting: Current user: root[39m
[33m====== [17:08:19] Starting: Current date: Tue 21 May 2024 05:08:19 PM +04[39m
[33m====== [17:08:19] Starting: Current version: 11[39m
[33m====== [17:08:19] Starting: Architecture: amd64[39m
[33m====== [17:08:19] Starting: Hostname: 3cx[39m
[33m====== [17:08:19] Starting: Hypervisor: vmware[39m
> Execute apt command simulation on "update"
> Execute apt command on "update"
Ign:1 http://repo.3cx.com/debian/1809 bullseye InRelease
Ign:2 http://repo.3cx.com/debian-security/1809 bullseye-security InRelease
Hit:3 http://repo.3cx.com/3cx buster-testing InRelease
Hit:4 http://repo.3cx.com/3cx buster InRelease
Err:6 http://repo.3cx.com/debian-security/1809 bullseye-security Release
Reading package lists...
E: The repository 'http://repo.3cx.com/debian/1809 bullseye Release' does not have a Release file.
E: The repository 'http://repo.3cx.com/debian-security/1809 bullseye-security Release' does not have a Release file.
[33m====== [17:08:29] Upgrade Result: *******************************************[39m
  "result": "Upgrade",
  "time": "21-05-2024 17:08:29",
  "title": "Package Update Failed",
  "message": "An error occurred while upgrading package: update"
[31m[17:08] Upgrade: Package Update Failed - 0[39m
In the APT sources, replace bullseye with buster (also remove “-security”) and try upgrading again to see if that works (if you know how to do it that is). Make sure you take a backup/snapshot of your system before taking any action.
Otherwise, take a full 3CX backup, spawn a new machine from our Debian 12 ISO and restore it. It will probably take less time and you start fresh.
Hello again "buster" is helped but another issue:
[33m====== [22:43:45] Preparation: Fetch postgresql cluster: 13 main 5432 online postgres /var/lib/postgresql/13/main /var/log/postgresql/postgresql-13-main.log[39m
[33m====== [22:43:48] Preparation: Could not get postgresql cluster version from the settings database. Got: 13. Trying from pg_lsclusters result...[39m
[33m====== [22:43:48] Preparation: Unable to determine postgresql cluster version. Got: 13. Aborting...[39m
[33m====== [22:43:49] Upgrade Result: *******************************************[39m
"result": "aborted",
"time": "21-05-2024 22:43:48",
"title": "Unable to determine the PostgreSQL cluster version",
"message": "The script was unable to determine PostgreSQL cluster version. This may be a result of postgresql misconfiguration or service problem."
[31m[22:43] aborted: Unable to determine the PostgreSQL cluster version - 0[39m
i think clean install with restore best practice... is there can be some troubles when restoring from 18 version to 20?
Yes the best option (and recommended way) is to start clean by deploying our Debian 12 ISO and restoring from a backup.
Prior upgrading, please go over this V20 Upgrade Checklist: https://www.3cx.com/blog/releases/v20-upgrade-checklist-faq/ (mostly Steps 1-7)
To add to that:
- If you have Scheduled reports they need to be re-done
- DTMF IVR is not available
Reactions: Sergey Yezhov
hello,
last question DTMF IVR will NOT be available or will be available later in updates??
noufir
