Update presence from Teams clients to 3CX Apps failed
58voip.com
Platinum Distributor
Hi ,
We cheched the option Update presence from Teams clients to 3CX Apps.
But it doesn't work.
Update presence from 3CX Apps to Teams clients is ok.
Thanks,
Frank
Hi, 2 possible solutions for you. either of them should work.
1. You will probably need to adjust the application permission in Entra. Add Presence.ReadWrite.All permission
Applications-> App Registration -> 3CX Phone System -> API Permission (see snapshot)
2. In Entra delete the 3CX App and perform the integration again in 3CX. Before doing the integration again, make sure you have both presence checked under users -> Ms365
Hamun.
KylieWilderman
