Upgraded from V18 to V20 and cannot locate Call Flow Apps
MR R
Trial User
I simply upgraded to V20 and logged into 3CX, click on Admin, then Advance and there is no Call Flow Apps? I am running PRO, is there something Im missing?
From what I understand, Version 20 is still only for testing purposes only and may still be missing things that will be in the final release.
It's been moved to Integrations
Reactions: jed
I can't find call flow apps in v20??? @richiewhite said it's under integrations but not for me. Screenshot 2024-01-18 120414.pngScreenshot 2024-01-18 120238.png
It's there:
1705605134764.pngEnsure you are signed in with a correct user and are on the correct version.
I am logged in as the System Owner on v20.0 Update 0 build 1494, my system is up to date. It is not there.
Your system is hosted by 3CX; CFD is not currently an option for the 3CX-hosted system.
I was running on a raspberry pi but that is no longer supported so I had no other option... will this be a feature in a later release? This is extremely frustrating.
We don't as yet have any information on this.
meanwhile, you can always move to self-host in DigitalOcean and have access to CFDs, if that's absolutely necessary.
Senergia
