Upgrading Azure-hosted Linux ver16 to ver18
Mtdata
I set up the PBX on azure so long ago I can't for the life of me remember how to upgrade it. we have upgraded from 15-16 over the years but would like to upgrade to 18.
I have logged into my azure portal but nothing is popping out at me. is there a tutorial for this somewhere?
We are running on the standard version and would like to stay there. we have 3 phones.
Cheers
Todd.
Make sure you have a backup and then login to the management console and go to Settings >> Updates.
It will update you to v18 and Debian 10.
Reactions: NickD_3CX
We have our 3CX hosted in Azure (A1v2) and did the update not long ago. It went just fine and we were only down 15 minutes or so.
Do make sure to take an update beforehand though, just to be safe.
Silent_Guru
