When upgrading your PBX to 3CX v20 from v18, the BLFs on Grandstream GXP2135 phones should generally continue to work, but there are a few things to keep in mind:
1. Firmware Compatibility: Ensure that the Grandstream phones are running the latest supported firmware. 3CX v20 might require updated phone firmware for full compatibility.
2. Provisioning Templates: 3CX v20 introduces changes to provisioning, so it's important to re-provision your phones after the upgrade. Check if any custom templates you use for BLFs need adjustments.
3. BLF Configuration in 3CX: BLF settings should be retained during the upgrade, but it’s always a good practice to double-check the settings post-upgrade to ensure they’ve been properly applied.
4. Phone Reboots: After the PBX upgrade, the phones may reboot, re-provision, or require a manual reboot to apply any new settings from v20.
you will also need to upgrade the 3CX SBC to ensure compatibility and optimal performance.
