Upgrading SBC to 18.1.34 (beta) Raspberry Pi3+
blarkin
Hi.. when I attempt to upgrade our SBC's to version 18.1.34 (beta) (host on raspberry Pi3+) it does not do anything? Is this Raspberry device still supported? (Currently running 18.0.30) I cannot SSH into the device most likely due to SSH not being enabled, but was trying to upgrade through the Management Console.
Hi!
The currently recommended Raspberry hardware is the RPi4 B4 or B8, however you *should* be able to still install the SBC on the RPi3.
What I find most likely is this to be some repository problem where raspberry might have 'deprecated' one of the repos you are using, causing this to fail.
What I would suggest is following this guide from the beginning:
https://www.3cx.com/docs/installing-pbx-raspberry-pi/
I know the point was to upgrade it via the MC, but seeing that this isn't currently working, you need to troubleshoot, and seeing that you cannot log in via SSH, you will most likely need to go on site. If you are going to go on site, you might as well re-flash the SD from the beginning to also do a fresh install of the OS while you're at it.
Even better, if you have your hands on a RPi4, replace it.
Thank you for your reply.. hoping to upgrade soon.
megalmazan
