UPLOAD SCRIPT CFD : Number : Value already used
ClercGA
Gold Partner
I have created a 512 extension.
I have developed a cfd.
I get the following message when I upload the script
I don't understand the error.
Thank you in advance for your help.
3CX: Version 20 update 2
CFD: 18.5.8.0
When you upload a CFD that is setup to use 512 as extension, you DO NOT create an extension in 3CX anywhere. The CFD will have its own internal extension.
In order to upload a CFD app, one of the following conditions must be met:
1) The extension doesn't exist. In this case the 3CX console will create a new extension for the CFD app and set the C# script to it.
2) The extension exists, but it's a RoutePoint (i.e. an existing CFD app). In this case the 3CX console assumes that you're updating an existing CFD app, and changes the existing C# script with the new one.
KylieWilderman
