Urgent: French SIP Trunk Providers Missing After Update 10
SAV.IB
Gold Partner
I am experiencing a major issue since installing Update 10 on my Multi-Tenant server.
French providers such as Phenix, OVH, and others have disappeared from the list of SIP Trunk providers.
I now see only three SIP Trunk providers available.
Since this update, I am no longer able to configure trunks for my customers.
Could you please tell me how to make these SIP Trunk providers reappear or restore them to the list?
This issue is very urgent, as I need to configure a trunk today for a new customer and I am currently blocked.
Thank you in advance for your assistance and for your prompt response.
Kind regards,
Alain
Hello @SAV.IB
Please note that in Multi-Tenant/Multi-Company systems, some of the SIP trunk provider templates that are available in Single-Tenant deployments will not be available.
This is because SIP trunk providers used in Multi-Tenant must support multiple simultaneous connections from the same IP address, using the rinstance parameter, to prevent potential conflicts between tenants.
While certain providers may be supported for standard systems, they may not be validated for Multi-Tenant, which is why their templates are not being shown in the available providers list.
As an alternative, you may consider switching to Single-Tenant mode to configure the desired provider. However, if you intend to use the provider in a Multi-Tenant environment, you should first ensure that it supports multiple connections from the same IP address using the rinstance parameter.
You can find additional information in our 3CX Multi Tenant documentation, under the SIP Trunks & Call Management section: https://www.3cx.com/pbx/multi-tenant/
Since setting up my multi-tenant server, the SIP trunks from my provider Phenix have been working perfectly. I do not understand this regression, which blocks certain providers even though they operate without any issues.
I am now blocked because I need to configure new SIP trunks.
Even as the System Owner, I no longer have the ability to choose the provider, and I cannot even manually configure a SIP trunk.
The problem is that disabling multi-tenant mode requires restarting the server. This would cause a service interruption for all customers currently online. Therefore, this is not a viable option, especially since I host more than 100 customer groups on this server.
I do not understand 3CX's policy of locking everything down in this way. This type of restriction risks driving customers away from 3CX.
I look forward to your response and to a quick solution to this issue.
Kind regards,
Alain
As a system owner you should be able to add templates back in as custom if you know them to work OK in MCM mode.
I’m experiencing this on a multi-company too, running Update 10. My existing trunks works fine, but I cannot select to add another.
Following the advice above, I created a custom copy of the provider template. It saves successfully but still doesn’t appear under Add Trunk. I have checked UK and Worldwide visibility.
Are you saying I will need to switch to Single-Tenant mode, make a custom template and switch back to MCM or am i missing somthing?
Aiiik
