Solved User can listen to other call
AABB
Trainee Partner
we have a problem with a PBX,
user can listen to calls even if the option "Can Barge in, listen or whisper (Available in Professional and Enterprise)" is disabled.
Any help ?
Any help ?
They should not be able to unless they listen to a call from a different user group where they do have the right.
Make sure to check all groups.
Thanks, i found that the groups had the option ON
devo.it
