User EXPORT containing multiple BLF
DBeaubien
Hello!
Did anybody try to export users with multiple BLF configured, the resulting .CSV is a MESS, can you provide an export option without the BLF's so the CSV does not guet messed up.
Thank you!
Hi @DBeaubien
It's not possible to export an extension and not include the BLFs. What can be done after exporting it to delete the Column that contains the BLF.
So with a 1000 users you tweak the .csv file, are you serious, v18 did not export BLF's
If you export all users in the same CSV the same column contains all BLFs for all users. All that needs to be done is select the column delete it and save the csv.
Reactions: jed and Evolute IT
Excuse me, did you ever try to export a user list with multiple BLF per user, did you open the resulting .csv file, it MESSE's up the file structure completely, unless there is a trick i don't know, where can i send an export privately
use moderncsv as editor
Reactions: jed
Microsoft Excel also works great. the BLF export/import is a helpful feature that some people have wanted for a while.
oh no, Libre Office is much better and has fewer quirks in recognition and conversion - just my experience
for pure CSV: Modern CSV
Reactions: jed and CentrexJ
Thank you for the heads UP on ModernCSV and Libre Office i will try that
Jeff_MKC
