User Management/ Extensions
Apache
I'm logged in to the dashboard at https://portal.3cx.com/ but it doesnt show any user accounts or extension numbers. I think I have one extension but dont seem to know the number and dont have the password. Thanks in advance for your help with this.
That’s your customer account; you need your server URL.
Are you talking about the "https://****.3cx.cloud/webclient" link that is listed under "My Systems" inside the portal?
You need to access this url in order to see the extension configuration.
Yes, exactly. How do I gain access?
It's not sending the password reset from the "forgot password" link.
Have you tried to reset for the correct email address?
You are a staff member? Your question seems like trolling... Doesnt seem very professional for a 3cx Representative.
Why my question is not valid?
You have created a Free SMB and you don't know the user or email?
The first user that is created will use the email you offered when you created the SMB, so my question was if you used the correct email and reset the password.
AshleyStokes
