v16 8A upgrade
Yellow_Flash
We have two 3cx instances, one used as LIVE and other one as backup.
Only one of these instances will be active at any given time frame.
We had planned to upgrade both to v18 during the Easter Holidays.
The issue we are having now is that, I had upgraded one of the instances to v16 8A but the backup instance was only upgraded to v16 Update 8.
For some reason, they forgot to upgrade it to 8A and now it is already March.
I came back to office today and found out this issue.
What can be done now?
Is it possible to still upgrade to 8A from management console?
Please let me know.
Thank you
On the blog - https://www.3cx.com/blog/releases/wc-update-v168a/
It says 'You must update your v16 before mid march to avoid any licensing issues' - you should be fine to upgrade in the next couple of days
Thank you for the information.
I'm concerned about the email that 3cx had sent which says "The current activation end point will be terminated on 28th February 2022".
Also, Both the 3cx instances are using the same license and one of them is on the v16 8A.
Hi @TechieGuy,
Can you PM me the license key to check it's validity?
Silent_Guru
