Unsupported v18 3CX Linux - Host Firewall
ipt_dude
Has anyone installed the FortiClient host firewall on a v18 3CX / Linux ? Does anyone use host based firewalls on their installation?
Thanks,
Amir
I would bother adding extra load to your PBX, and installing 3rd party apps borders on unsupported.
if you want to use host firewall then stick it on another machine in front of the PBX.
Im assuming youre asking this because your PBX is in the cloud?
It's on prem. We are just trying to have the highest level of IT security across all platforms.
I'm curious to know if this is actually something that would be "unsupported" by 3CX.
Generally installing 3rd party software is not supported, you are of course free to do as you please but should you submit a support ticket with 3CX it may get suspended until all 3rd party software is uninstalled.
Reactions: ipt_dude
We will just keep it regularly patched. Thanks.
Reactions: ChrisC_3CX
gmacinit
