V20 and Patton PRI Gateway
Niroti
I have been fighting with trying to get a Patton 4170 PRI Gateway to register with V20.
I have tried using the Patton Wizard to create a configuration file and loaded it on the Patton. I then imported the Patton Generic Gateway template into 3CX and configured it. I just can't get the Gateway to register.
Has anyone succeeded in getting this working on V20?
Did you get this resolved, and if so what did you do
I ended up calling Patton Support and they helped me get it connected to 3CX.
Reactions: N_G
SG_F7
