V20 Android app - how to disable
Demvaril
The new V20 android app doesnt appear to have any way of disabling it. Anyone any idea on how to do this? We have a customer who wants to disable at random times whilst at the same time he wants his deskphone to ring so only disabling the app is an option.
TIA
David.
Nevermind, found it. Long press the account name and select disable.
Alternatively, setup one of the status to not have push enabled.
Reactions: Vali_3CX
@Demvaril alertinatively, you can disable Accept PUSH notifications
Tap on Status icon [top right] > Select pencil icon next to Available > Scroll all the way down and disable Sccept PUSH notification
You can also do this from the webclient
Settings > Call Forwarding > Available > Same setting
cvanderzwan
