- Joined
- Jan 12, 2023
- Messages
- 4
- Reaction score
- 3
Version 20.0 Update 4 (Build 487 Release)
Good morning,
https://www.3cx.com/docs/call-control-api-endpoints/
I am trying to connect to the new Call Control API, but I its not that cleat how to Authenticate.
I have created an app on the admin
I am using curl php. looking at some documentation it says to use https://???.3cx.uk/api/connect?appId= but i get 404 error.
I have managed to connect and use the xapi system, with no issues.
The make call function on xapi does not work well, as it will ring only on one device. I see that on call-control I should be able to get a list of devices per user so the user can select the device.
has anyone got the authentication working?
Good morning,
