V20 clear call log on phone
graham_uk
We have approx 140 Yealink phones deployed on a holiday park. The system (installed by others) is V20 cloud based with SBCs. It isn't integrated into the PMS as we don't need the maid status or billing etc...
What we do need is to clear down the locally held call logs on the phones so the next guests can't see the numbers dialled (or recieved) by the previous guest. Reprovisiong doesn't clear this locally held info. Any ideas - other than factory defaulting.... We would be happy for this info to be cleared regularly at set times, not necessarily on check in/out.
I had a look through the spec of the "Hotel module integration" but can't see this mentioned either?
Many thanks.
On the Team page in the web client click the 3 dots by that extension, and pick Clear.
The logged in user must be at least a Receptionist, as I recall, and have Operations checked under their User > View tab.
ARKC
