V20 interaction log E.164
nonexprt
Platinum Partner
Hi!
I dont know if this is a V20 Problem only. Perhaps it can be found in earlier versions.
When you open the contact you see the interaction log on the right side. when you update the contact with a new number or change the number to or from the E164 format, "00" -> "+" or "+" -> "00", you loose the log. when you undo changes it appears again. So i think it would be nice to see all interactions, doesnt matter if it is 00 or + in first order in the contact.
a good thing to say:
it is really nice to have the new checkbox that the log is available or not at all ! a great new feature in V20 for data protection / privacy in government-pbx!
Upvote 1
