V20 PBX Status info missing
Peter Carlson
upgraded to V20 and I cant find PBX info
  • Trunks up 1/1
  • Extensions up 20/25
  • Number of calls in use 0/8
  • Blacklisted IPs
etc
Hi there.
Active calls can be found in V20 update 1 (currently beta version), however the rest of the option are in different location.
Blacklisted IPs are in the Advanced >> IP blacklist
Extensions are under the Users section
Trunks you can see in Voice & Chat
Reactions: N_G and Evolute IT
is it because of the loss of V18 admin console the v20 layout is totally different or could it be the same even with webclient admin?
FWIW, a simple green check mark vs a badge with #/# is pretty useless
AshleyStokes
