- Joined
- Apr 20, 2021
- Messages
- 42
- Reaction score
- 4
Yes, its a none supported trunk. The 'supported' trunks are very limited in Australia but I have used the trunks for at least 3 years now. I will try the export. Thanks for your quick response.Is this a non supported trunk?
Have you tried an export/import and viewed the XML?
Thanks Dimitris, yes its 3CX hosted. I understand why the trunk from the same provider works on a system upgraded from v18 to v20 though.Hello @Craig Catlow,
Is your Instance Hosted by 3CX?
In 3CX Hosted Generic SIP Trunk is not available. Only 3CX Supported SIP Trunks are available at the moment.
This option won't allow me to change the Authentication ID (SIP User ID)
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
