V20: unable to download several recordings simultaneously
estragon
Good evening, I installed the V20 (build 1620) and thank you for the work which apparently works well.
When I want to download a conversation recording file in the admin console, if I choose a single file the download button works correctly and everything is ok.
But when I choose several files, the download button becomes inactive!
Did I make a wrong move? Or is it a problem with my install (a Debian)? Otherwise it's a bug and at this point how can I report it?
Thanks. Regards.
UP : can please some one make a tray ? Thanks.
I will confirm that you can only download 1 at a time, you can delete many at once, on my install.
Thanks for the feedback.
So it's definitely a bug. Where can we report it?
Thanks.
Regards.
Yup - same problems. I wish we never upgraded to v20
In v18, it used to to download multiple recordings as a zip file, but in V20 it will download only a single time at a time.
ARKC
