V20 Update 9 — one-way audio on queue answer with TLS/SRTP trunk (lifecell) — SRTP decrypt failures — workaround: disable SRTP
itspec.pavlikovskyi
SOHO User
We are experiencing a reproducible one-way audio issue after upgrading to Version 20.0 Update 9 (Build 995). The problem does not occur on direct extension calls in all cases we tested, but it does occur reliably on inbound calls answered from a call queue.
Symptoms​
  • Inbound call → queue → agent answers
  • Agent → caller: OK (caller hears the agent)
  • Caller → agent: NOT OK (agent hears nothing)
  • Call recording on PBX also has no caller audio (only agent side)
  • Outbound callback from agent works fine (both directions OK)
This points to an issue on the inbound trunk media leg, not the agent endpoint or firewall.
Environment​
  • 3CX V20.0 Update 9 (Build 995) on-prem (Linux)
  • PBX behind NAT (public IP configured in 3CX network settings)
  • Firewall Checker: passes
  • SIP trunk: lifecell(Ukrainian provider)
    • Transport: TLS
    • SRTP Mode: Enabled
  • Remote agents via 3CX Tunnel (Windows client)
  • Issue started after Update 9 (worked before the update)
What we tried (did NOT fix it)​
  • Enable PBX Delivers Audio on agent extension
  • Firewall Checker / RTP port range verification
  • Various queue scenarios
Root cause found in logs​
With Activity Log / Media Server logging enabled, we captured ~1400+ errors during a single test call:
SrtpTransformer.cpp(145): Failed to decrypt RTP packet: error = 7
Timeline correlation:
  • Errors start immediately when the inbound trunk SRTP session is established (within ~20 ms of SDP negotiation)
  • Errors continue after the agent answers from the queue
  • Trunk SDP uses RTP/SAVP with AEAD_AES_256_GCM
Provider media appears to reach the PBX (UDP packets visible in tcpdump), but 3CX cannot decrypt inbound SRTP → no caller audio in bridge/recording.
At queue answer, Media Server also shows media leg changes (MOH/queue leg removed, agent leg joined), but the SRTP decrypt failure is present from the start of the trunk session, not only at answer.
Workaround (confirmed)​
Setting trunk SRTP Mode = Disabled fixes the issue completely (queue answer, recording, both directions).
We prefer to keep SRTP enabled for production, so this is only a temporary workaround.
Additional context:
We have been using this SIP trunk provider (lifecell) for a long time with the same configuration (TLS + SRTP Enabled). SRTP worked without issues before the Update 9 upgrade — there were no one-way audio problems, queue issues, or missing caller audio in recordings.
Nothing was changed on the provider side or on our firewall/NAT setup as part of this troubleshooting. The issue appeared only after upgrading to V20.0 Update 9 (Build 995).
Disabling SRTP on the trunk immediately resolves the problem, which strongly suggests a regression in 3CX Update 9 SRTP handling for this trunk, not a new provider or network misconfiguration.
Request​
Could the 3CX team investigate SRTP inbound decryption (auth_fail / error 7) with TLS + SRTP Enabled trunks on V20 Update 9, especially on queue inbound scenarios?
Thank you.
I have sent you a DM so we can further investigate your issue.
DejanMDS
