V20 upgrade no access from outside, cell app doesn't work.
MM1969
one of my version 18 systems had an internet failure so no access to trunks. i figured while it is down i will upgrade it to version 20 since they can't make calls anyway. I loaded a fresh copy of v20 just so i had a clean install on the server. with the system being down (no internet)i had to make some adjustments so that i had internet access to install the new copy of linux v20. i switched to a different circuit loaded v20 restored my database and got the system up on the temp internet connection. when the original internet connection came up i did the procedure to change the public ip address (set ip to dhcp for wan and restart system) now if i ping the fqdn it responds with the right ip address but i can't access the system using the fqdn from outside. like my certificate isn't right or something. it automatically switches to http: and gives me an error.
I would like to change the fqdn anyways. this site is in FL not Al. What do i have to do to get outside access and the cell app working using the fqdn? now that i am v20 there is no going back. V18 i would just do a backup without license key and fqdn.
thanks you were exactly correct. i was using port 5001 for console access before the upgrade. fresh installs of v20 don't appear to allow you to connect using 5001 unless it was an upgraded system from v 18 to v20.
Just modify the port number in the SetupConfig.xml file before uploading to the PBX
tom.walker@blackcountryra
