Solved Verbose Logging in V20
Jan_Otto
Hi guys, how do I utilise verbose logging in V20
You can set it as per below screenshot but do not restart the services:
Thank you, I figured that one out, not restarting the services is a good tip, because it seems to reset logging level to low. Anyway where do I find the actual verbose log?
For the 3CX Hosted machines the default value is to keep the logs in Low, so restarting the services will always revert to low.
In order to get the logs you just have to press the Support Info and the logs will be downloaded:
Found it Thank you
Glad to assist ;)
PacketPilgrim
