video conferencing service temporarily not available please try later (0x0018)
Infinitysl
Hello everyone,
if we try to pres over "start now" button of video meeting from some time we get error - "video conferencing service temporarily not available please try later (0x0018)".
I search for some fix or any explanation but find only one on forum ( https://www.3cx.com/community/threa...vailable-please-try-again-later-0x0018.82707/ )
My server is
Linux 10 original ISO from 3cx
Product: Enterprise Annual
Version Number: 18.0 (Build 20)
Number of Simult. Calls: 32
Meeting Seats: 250
License status: Activated
Hello @Infinitysl , this error means that your PBX is not able to contact Webmeeting server https://wmr.3cx.net.
Please check Webmeeting logs on your PBX and look for errors.
Hello @MarcelloV
on my 3CXWebMeeting.log I see some error but not familiar whit this type of errors and what action to take
parts of log whit errors:
2024-02-20 14:33:21.1058|WARN|McuRouter.ApiQueue|API Request Failed: SetPbxParameters API Request Timeout
2024-02-20 14:34:05.6032|ERROR|WebMeetingBridge.RouterController|{"result":false,"error":"Request Error"}
2024-02-20 14:34:29.7137|ERROR|WebMeetingBridge.RouterController|{"result":false,"error":"Request Error"}
2024-02-20 14:34:30.5870|ERROR|WebMeetingBridge.RouterController|{"result":false,"error":"Request Error"}
2024-02-20 14:34:31.6410|ERROR|WebMeetingBridge.RouterController|{"result":false,"error":"Request Error"}
2024-02-20 14:34:32.3734|ERROR|WebMeetingBridge.RouterController|{"result":false,"error":"Request Error"}
2024-02-20 14:34:32.9603|ERROR|WebMeetingBridge.RouterController|{"result":false,"error":"Request Error"}
2024-02-20 14:34:41.7168|ERROR|WebMeetingBridge.RouterController|{"result":false,"error":"Request Error"}
2024-02-20 14:34:46.1077|WARN|McuRouter.ApiQueue|API Request Failed: SetPbxParameters API Request Timeout
2024-02-20 14:35:11.5971|ERROR|WebMeetingBridge.RouterController|{"result":false,"error":"Request Error"}
2024-02-20 14:35:18.6164|ERROR|WebMeetingBridge.RouterController|{"result":false,"error":"Request Error"}
2024-02-20 14:36:18.1134|WARN|McuRouter.ApiQueue|API Request Failed: SetPbxParameters API Request Timeout
2024-02-20 14:37:35.9538|ERROR|WebMeetingBridge.RouterController|{"result":false,"error":"Request Error"}
2024-02-20 14:37:36.7860|ERROR|WebMeetingBridge.RouterController|{"result":false,"error":"Request Error"}
2024-02-20 14:37:53.1166|WARN|McuRouter.ApiQueue|API Request Failed: SetPbxParameters API Request Timeout
2024-02-20 14:38:05.9833|ERROR|WebMeetingBridge.RouterController|{"result":false,"error":"Request Error"}
2024-02-20 14:38:55.8577|INFO|McuRouter.Config|LogFile=/var/lib/3cxpbx/Instance1/Data/Logs/ Level=Debug
2024-02-20 14:39:11.2819|INFO|System.Net.Http.HttpClient.Default.LogicalHandler|Start processing HTTP request POST https://wmr.3cx.net/router
2024-02-20 14:39:11.2819|INFO|System.Net.Http.HttpClient.Default.ClientHandler|Sending HTTP request POST https://wmr.3cx.net/router
2024-02-20 14:39:11.4234|INFO|System.Net.Http.HttpClient.Default.ClientHandler|Received HTTP response headers after 134.5834ms - 200
2024-02-20 14:39:11.4234|INFO|System.Net.Http.HttpClient.Default.LogicalHandler|End processing HTTP request after 139.161ms - 200
2024-02-20 14:39:11.4234|DEBUG|WebMeetingBridge.WmController|SendJsonHttpRequest Reply: {"result":false,"error":"Request Error"}
2024-02-20 14:39:11.4234|ERROR|WebMeetingBridge.RouterController|{"result":false,"error":"Request Error"}
2024-02-20 14:39:11.4234|INFO|Microsoft.AspNetCore.Mvc.Infrastructure.ContentResultExecutor|Executing ContentResult with HTTP Response ContentType of application/json
2024-02-20 14:39:11.4234|INFO|Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker|Executed action WebMeetingBridge.RouterController.GetAsync (WebMeetingBridge) in 142.5736ms
2024-02-20 14:39:11.4234|INFO|Microsoft.AspNetCore.Routing.EndpointMiddleware|Executed endpoint 'WebMeetingBridge.RouterController.GetAsync (WebMeetingBridge)'
2024-02-20 09:18:34.3862|ERROR|WebMeetingBridge.RouterController|{"result":false,"error":"Request Error"}
2024-02-20 09:18:40.9799|WARN|WebMeetingBridge.JoinController|Unknown User-Agent: WhatsApp/2.2401.5 W detected as unknown-unknown-unknown
2024-02-20 09:19:12.2568|ERROR|WebMeetingBridge.RouterController|{"result":false,"error":"Request Error"}
2024-02-20 09:19:14.0311|ERROR|WebMeetingBridge.RouterController|{"result":false,"error":"Request Error"}
2024-02-20 09:19:14.8541|ERROR|WebMeetingBridge.RouterController|{"result":false,"error":"Request Error"}
2024-02-20 09:19:20.1323|ERROR|WebMeetingBridge.RouterController|{"result":false,"error":"Request Error"}
2024-02-20 09:19:24.1941|ERROR|WebMeetingBridge.RouterController|{"result":false,"error":"Request Error"}
2024-02-20 09:19:38.2244|WARN|McuRouter.ApiQueue|API Request Failed: SetPbxParameters API Request Timeout
2024-02-20 09:20:06.6877|ERROR|WebMeetingBridge.RouterController|{"result":false,"error":"Request Error"}
2024-02-20 09:21:11.2317|WARN|McuRouter.ApiQueue|API Request Failed: SetPbxParameters API Request Timeout
2024-02-20 09:22:04.0546|ERROR|WebMeetingBridge.RouterController|{"result":false,"error":"Request Error"}
2024-02-20 09:26:41.0388|ERROR|WebMeetingBridge.RouterController|{"result":false,"error":"Request Error"}
2024-02-20 09:43:29.3016|WARN|McuRouter.ApiQueue|API Request Failed: SetPbxParameters API Request Timeout
2024-02-20 09:45:03.3061|WARN|McuRouter.ApiQueue|API Request Failed: SetPbxParameters API Request Timeout
and from the server I test access to the site
Hello, it seems that you are experiencing an intermittent timeout issue on your PBX while contacting wmr.3cx.net. I contacted you privately for more details about your PBX, so we can troubleshoot properly.
As you suggested, after restarting network no change, after restarting PBX server the error disappeared and everything works.
Reactions: Infinitysl
Problem solved!
Thanks for the quick replies and additional information.
Your suggestion to restart solved the problem.
Graham Robertson
