View clients connected to SBC.
KrisEiT
Hi , I was wondering if it was possible to view clients that are connected to a Raspberry Pi SBC? I have an issue where we are migrating desk phones from an old SBC to a new one, we've gone through the users and moved each one over to the new SBC but for some reason the stats on the old SBC still shows a number of clients connected to it.
I can't seem to find a way to identify what those clients are or if its just a case of some phones are still using the old SBC even after changing the setting to use the new one?
thanks for any advice / help
Hi @KrisEiT from the pbx management console you can see the provisioned phones and which sbc are they using.
Also you can export the extensions via CSV file and check the provisioning setting to know which extensions are still with the old sbc.
Have a great day!
Reactions: KrisEiT
Have a great day!
Thank you, it appears I was going completely blind and didn't spot the column in the phones view, appreciate the help.
Kris
Reactions: Alejandro_3CX
You are welcome!
Jake_Southern
