Vocus SIP Trunk - V20 Update 2
whiteym
Gold Partner
Hi All,
I have noticed that from Update 1 to Update 2 the Vocus Trunk Template no longer has the outbound proxy option. This will possible cause issues as they use different outbound proxies depending on where you are located.
Can this option be brought back?
I'm happy to provide info from the configuration guide supplied by Vocus for this.
Also the default registrar/server should be iptel.vocus.net not the amcomvoice one.
Can you please create a support ticket so we can check this further?
We will take it from there. Thank you.
youwillbrun
