Voice recordings control
atlantisegidek
Forum User
Hi my speak a weak. Sorry about that.
I have Professional Annual.
I use 3cxforWindows. I can see and control call voice recordings. I don't want to see and control them. How can I do it? Thank you.
Under the extension of the user click
Options
Turn off
Under Rights
Turn off
Reactions: atlantisegidek
To disable functions.
Screen 1 - Under Phone Provisioning for the Extension, select 3CX App
Untick 'Show Call Recordings'
Screen 2 - Under Option for the extension
Untick 'llow users to start and stop recording (By pressing rec on off button in the clients / IP Phone) (Available in Enterprise only)'
Thank you for answer.
My licence Professional Annual.
It's passive here. I can't control it.
and user privileges. Voice recording can open and stop. There is a mistake.
the ability to set the initial recording state or changing/preventing the recording state by a user requires ENT edition of the PBX.
I know. My licence Professional Annual. Some users can stop and start recording audio. And I can't control it. This is a big problem. Please support......
You would need to upgrade your license to ENT from PRO to gain access to this feature.
https://www.3cx.com/ordering/pricing/
Thank you for advice but I guess you didn't understand me. I don't want to upgrade ENT. According to my current license, this feature is required in active state. In other words, it should not stop and start recording while making a call. I am taking a photo for you again.
You see, it is able to open and close the recording.
I can't control this.
And my licence
If you set "Recording OFF" and uncheck the "Allow users to start and stop" option, which you cannot change in Pro licensing, then you have created a state where the user will not be able to record any call.
Thats what you are looking for, correct?
--> Ent Licensing
3K8iMGWviZ
