Voicemail wav files not attached to email - single user
FLTRU16
I have a single user that no longer is receiving voicemails attachments on her email notifications. I have verified the emails send in the System > Email setting. I have the Email Options set to "Send voicemail as attachment" I have confirmed that voicemails are being attached to other email account just not this one.
Any idea where to look next?
Do they have transcription and is it working OK? Could be a factor.
Enable verbose logging, leave a vm for this user. Then download SystemService.log and filter by BoxesMonitor.
The last few lines will help with troubleshooting.
I do not think we have transcription as the email only contain this when we receive a VM alert.
Here is the log file from the VM I left on the users extension. I cannot see any different from the logs when I left myself a VM and it was delivered correctly.
2025/11/20 08:57:18.210|0005|Trac| [_3CX.BoxesMonitor] 1000.VoiceMailBox has been updated: 3/2
2025/11/20 08:57:18.210|0005|Trac| [_3CX.BoxesMonitor] state= for 1000/vmail_2010_1000_20251120135707
2025/11/20 08:57:18.210|0005|Trac| [TCXSpeech.TranscriptionService] SPEECH Mail Transcription not needed by 1000
2025/11/20 08:57:18.210|0005|Trac| [_3CX.BoxesMonitor] DELIVER 1000/vmail_2010_1000_20251120135707 now
2025/11/20 08:57:18.210|0046|Debg| Dequeue Inserted.S_VOICEMAIL.8766
2025/11/20 08:57:18.211|0038|Debg| [_3CX.BoxesMonitor] Schedule delivery of 1000/vmail_2010_1000_20251120135707: 1
2025/11/20 08:57:18.211|0038|Trac| [_3CX.BoxesMonitor] state= for 1000/vmail_2010_1000_20251120135707
2025/11/20 08:57:18.211|0038|Trac| [TCXSpeech.TranscriptionService] SPEECH Mail Transcription not needed by 1000
2025/11/20 08:57:18.211|0038|Debg| [_3CX.BoxesMonitor] Delivery in progress
2025/11/20 08:57:18.211|0038|Info| [_3CX.BoxesMonitor] Creating email notification for 1000
2025/11/20 08:57:18.211|0038|Trac| [Npgsql.Connection] Opening connection to /var/run/postgresql:5432/database_single...
2025/11/20 08:57:18.211|0038|Debg| [Npgsql.Connection] Opened connection to /var/run/postgresql:5432/database_single
2025/11/20 08:57:18.211|0038|Trac| [Npgsql.Connection] Start user action
2025/11/20 08:57:18.211|0038|Debg| [Npgsql.Command] Executing command: SELECT contact FROM crm_cache WHERE number=$1 ORDER BY last_checked DESC LIMIT 1
2025/11/20 08:57:18.213|0007|Trac| [Npgsql.Command] Cleaning up reader
2025/11/20 08:57:18.214|0007|Info| [Npgsql.Command] Command execution completed (duration=2ms): SELECT contact FROM crm_cache WHERE number=$1 ORDER BY last_checked DESC LIMIT 1
2025/11/20 08:57:18.214|0007|Trac| [Npgsql.Connection] End user action
2025/11/20 08:57:18.214|0007|Trac| [Npgsql.Connection] Closing connection to /var/run/postgresql:5432/database_single...
2025/11/20 08:57:18.214|0007|Trac| [Npgsql.Connection] Start user action
2025/11/20 08:57:18.214|0007|Debg| [Npgsql.Connection] Closed connection to /var/run/postgresql:5432/database_single
2025/11/20 08:57:18.214|0007|Trac| [_3cxSystemService.OtherTasks.ContactResolver] CRM contact for 2010: (null)
2025/11/20 08:57:18.214|0007|Trac| [_3CX.BoxesMonitor] Contact has been resolved
2025/11/20 08:57:18.214|0007|Info| [_3CX.BoxesMonitor] Attaching vmail_2010_1000_20251120135707 to email
2025/11/20 08:57:18.214|0007|Info| [_3CX.BoxesMonitor] Sending email notification to Useremail@My_Company.com
2025/11/20 08:57:18.225|0038|Info| [_3CX.Push.PushTransport] Response from FCM: projects/cx-firebase-push/messages/0:1763647038196970%fc376129f9fd7ecd
2025/11/20 08:57:18.247|0007|Info| [_3CX.HttpClient] Sending 'POST/2.0' to 'https://graph.microsoft.com/v1.0/users/3CXPhoneSystem@My_Company.com/sendMail'
2025/11/20 08:57:18.441|0038|Info| [_3CX.HttpClient] Received '202 Accepted' after 270.9ms
2025/11/20 08:57:18.516|0038|Info| [_3CX.HttpClient] Received '202 Accepted' after 268.9ms
2025/11/20 08:57:18.516|0038|Info| [_3CX.BoxesMonitor] Email sent to Useremail@My_Company.com
2025/11/20 08:57:18.516|0038|Debg| [_3CX.BoxesMonitor] Delivery removed: 0
2025/11/20 08:57:18.520|0005|Debg| Enqueue Updated.S_VOICEMAIL.8766
2025/11/20 08:57:18.520|0038|Debg| Dequeue Updated.S_VOICEMAIL.8766
2025/11/20 08:57:18.520|0005|Trac| [_3CX.BoxesMonitor] Delivery finished for 1000/vmail_2010_1000_20251120135707
2025/11/20 08:57:19.212|0005|Debg| Enqueue Updated.VMBOXINFO.5
2025/11/20 08:57:19.212|0038|Debg| Dequeue Updated.VMBOXINFO.5
2025/11/20 08:57:19.213|0046|Trac| [Npgsql.Connection] Opening connection to /var/run/postgresql:5432/database_single...
2025/11/20 08:57:19.213|0046|Debg| [Npgsql.Connection] Opened connection to /var/run/postgresql:5432/database_single
2025/11/20 08:57:19.213|0046|Trac| [Npgsql.Connection] Start user action
2025/11/20 08:57:19.213|0046|Debg| [Npgsql.Command] Executing command: SELECT id_recording FROM recordings ORDER BY id_recording DESC LIMIT 1
2025/11/20 08:57:19.213|0017|Info| [_3CX.BoxesMonitor] 1000.VoiceMailBox UPDATE: 3/2
2025/11/20 08:57:19.214|0017|Trac| [Npgsql.Command] Cleaning up reader
2025/11/20 08:57:19.214|0017|Info| [Npgsql.Command] Command execution completed (duration=1ms): SELECT id_recording FROM recordings ORDER BY id_recording DESC LIMIT 1
2025/11/20 08:57:19.214|0017|Trac| [Npgsql.Connection] End user action
2025/11/20 08:57:19.214|0017|Trac| [Npgsql.Connection] Closing connection to /var/run/postgresql:5432/database_single...
2025/11/20 08:57:19.214|0017|Trac| [Npgsql.Connection] Start user action
2025/11/20 08:57:19.214|0017|Debg| [Npgsql.Connection] Closed connection to /var/run/postgresql:5432/database_single
2025/11/20 08:57:19.515|0005|Debg| Enqueue Updated.SBCRUNTIMEDATA.8
2025/11/20 08:57:19.515|0005|Debg| Enqueue Updated.SBCRUNTIMEDATA.7
Yes, the email was successfully sent. That's where the responsibility of 3CX ends.
I get that but the 3CX is not sending the attached VM in the email. I think I might have stumbled on why.
Left 1st VM and followed the prompts to press # when done with the VM. User received a email notification that they had a VM but no wav file was attached.
I left a 2nd VM and just hung up. This time the user received the email notification WITH a wav file attached.
Does that make any sense?
When you just hang up, the vmail is treated as confirmed and gets saved.
When you press #, you also need to confirm with 0. So I wonder why vmail is saved at all like you say.
Is there a way to change the message to say just hang up? I prefer the K.I.S.S. method
Thank you all for this quick help.
One last question. Is there a way to change all users default greeting at once for Voicemail or does it need to be changed individually?
Select 2+ users then click the Edit button. They all have to have the save .wav file, however, it looks like you can still upload a file there.
Reactions: FLTRU16
tom.walker@blackcountryra
