Solved Voicemails press * not responding
Uasgher
New User
When I press * in voicemail it will not divert to the operator. It keep repeating the same message?
How can I transfer it to the main IVR when someone press *
Hi @Uasgher,
To confirm, if you dial internally to an unregistered extension that forwards to VM, does the same thing happen?
Does this only happen for a specific extension or for all?
Its for all, I dial internally or externally it remains same
Just wanted to understand, how it should be ideally?
When someone presses * what should it do?
When you're forwarded to VM of an extension, and you press *, it should send you to the Operator extension (default 100), and will follow the routing you set there.
How can I change the default extension from 100 to other if we want it to?
Hi @Uasgher,
The option is set in the Management Console >> Settings >> General >> Operator Extension. Note that is only accepts Extensions, but no reason why you couldn't make a Dummy / Routing extension that will route to an IVR if you'd like.
Reactions: jed
Ok I got it now. thanks for the help
Reactions: VasilisV_3CX
Sure thing @Uasgher, feel free to open a new thread if you'd like any more information or assistance.
Reactions: Uasgher
Bluebox Global
