voip.ms enable sending sms text?
Song
Just wondering if I can use voip.ms as the sip provider to send text? I can enable sms text on the voip.ms side. But how do i get 3cx to enable sms txt messaging using the 3cx app?
1. Do I need to find a sip provider that support sms?
2. Do I need to assign a DID to the extension?
Thank you.
Please note that VoIP.ms is not a supported provider for SMS.
1. We have a list of providers that are supported for SMS as seen in the screenshot below from the management console
2. Please check the guide on how SMS need to be configured: https://www.3cx.com/docs/manual/sms-text/
thank you..But I do need a DID for each user that want to send and receive sms text? correcT?
Yes if you would like each extension to receive SMS using their own dedicated number or you may consider directing a single SMS number to a call queue so that you may have multiple agents receive the SMS from a single number.
thank you!! will test it out..
estrezacafe111
