Voip.ms - multiple POP's
fs_tmartin
I've got a trunk successfully working with Voip.ms, but I'm looking to use multiple POP's instead of assigning them all to one.
So if I setup a second trunk with a different DID, and POP but same account number and password, that should work?
what this means sorry only POP i know (other than music) is Post Office Protocol, but I doubt this is what you want to say.
Point of Presence
As I recall (it's been a while since I set up an account with them), with VoIp.ms, they do allow that. Can't recall if you have to use a sub-account to make each unique. You will have to try it to confirm. I think that you simply specify, on their website, which one you are using for incoming calls, from each number. Outgoing doesn't matter as you can change the CID to whatever.
You can have multiple sub-accounts that point to different POPs. Each sub-account can be a trunk in 3CX.
Reactions: craigreilly
3K8iMGWviZ
