- Joined
- Jun 27, 2018
- Messages
- 8
- Reaction score
- 0
change the "CallerName" value to "From : Display Name" in the Inbound Parameters tab...
This is what I was missing. Thanks NickD and bigdessert!
Please note that the PBX does not behave differently in regards to providers when it is cloud or on premise based. If you are receiving a 403 forbidden error from Voip.ms i would recommend contacting them as they will be able to provider a better insight as to why the error is generated.Thank you, bigdessert - I will continue to try - but I would feel more comfortable if I knew VOIP.MS was working on the cloud based version. Do you have it working there?
We can currently only list a provider under a single country, but that is just a presentation thing, it does not limit their functionality in some way.@NickD_3CX Thanks but why is it only in CA area as they are also in US?
Glad we could assistFYI - VOIP.MS works nicely now for us.
Thanks to all for getting it certified.
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
