W52P Call Forbiden - Warning: 499 3CX "Caller is forbidden" - STUN Registered
raphaelmb
Hi Guys,
I hope someone can help, cause I'm tired of banging my head against the wall.
I'm having issues with this W52P base, first, it was the STUN registration, so I found out I could only do it after disabling the SS:/Cyphers under Security.
Managed to finally register the base, however, after that I started getting the Global Error message when calling out.
Surprisingly, incoming calls are working fine.
Here is what I get on the logs, any help it will be well appreciated.
The client is running the latest 3CX version hosted in-house.
18.0 (Build 418)
Is it only outside calls that are failing? If so, you may have them blocked in the extension settings. In the log you provided I see...
11/02/2022 4:24:30 PM - [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
Invite-UNK Recv Req INVITE from 219.88.64.130:5065 tid=397135449 Call-ID=0_848182767@192.168.13.95:
https://www.3cx.com/docs/source-identification-issues/
This device is old and not secure to use in a cloud install or as a remote phone, which appears you are doing.
DejanMDS
