WebClient with 3CX extension enabled integration not working
RogierP
since the installation of the chrome extension (2.0.0.10), the integration no longer works. Auto launch a Custom Contact URL using variables is not started. Is there another location where I need to add the URL to the Extension so the Auto launch will work again?
I am able to get 3rd party url to pop up in edge, not working in chrome.
Check what version you are in. Also make sure that you check the settings in Chrome Extension that are properly configured
gmacinit
