Solved Weblogin or PWA app login shows that the extension not registered
technotux
I have installed Version 20.0 Update 3 (Build 806 Release) on-premise, when i log in user extension through web or pwa app it shows user is not registered and all the incoming calls goes to voicemail and outgoing calls from web / pwa app works, but if login same user on the mobile / desktop app, it can receive incoming calls without any changes.
So the question is why 3CX is not recognizing Web or PWA app logged in user
Reactions: technotux
Thank you, it resolved the issue
Thank you for the update.
I'm glad that we helped.
ARKC
