Solved Webmeeting blank screen
dxfoxd
Last Tuesday I started a webmeeting without any issues. But from Wednesday I get a blank screen when trying to start a webmeeting. I've tried everyting (other browser, clear cookies and history) and assured that the extension has the right to start a webmeeting. Nothing helps. Is there any issue related to webmeeting which is changed? Is the use of webmeeting for free accounts revoked?
Peter
Hi Peter,
Kindly post a screenshot so we can see what you mean, or create a Webmeeting and send me the link in a private message to see if I can connect to it.
Thx!. The webmeeting url is [redacted]. Its active now.
I don't know if it is relevant, but the page shows lots of errors:
Strange, it seems to work fine from my end. We'll take a closer look at this btw.
Thx. I suggested my son's teacher to set up a short webmeeting with the class next week and it would be great when his issue is resolved.
same issue here. i tryed even with incognito but still the same!!!
@dxfoxd can you tell me whats your Chrome Version?
Solved: working here when I disabled Kaspersky total security and make kaspersky Firewall off
Reactions: JohnS_3CX
Chrome version 80.0.3987.163 (official build) (64-bits)
I must say the problem didn't occur after a restart. I did not try the disabling Kaspersky and then clear the cache yet, but will do the next time this error occurs.
I have the same problem, when i use Chrome,Microsoft Edge, Firefox, and Kaspersky Total Security enable (personally i can't work with a antivirus turned off), can you please try by installing Opera, i just tryed it and it work for me.
VOIPEric
