Whatsapp and multiple numbers
Louis1976
If you are using multiple numbers for Whatsapp (one for 3cx and another for another service) you can overcome this problem by using a proxy.
I'm using this script I found at https://github.com/pinebit/http-request-proxy
In the Whatsapp developers configuration a put our proxy script.
All messages for the 3CX number are forwarded to the webhook defined by 3CX.
Also, this way we save all media in our CRM that customers send us.
I hope this helps others :-)
Reactions: N_G
Hi, this script also work for single meta app with mupltiples numbers and one 3cx?
The goal is configure this proxy in meta webook, and then redirect to correct webook in 3cx with same token ?
I think that 3cx must allow single webhook to multiple numberID for this pourpose
I tried and works!
NortechTelecom
