Whatsapp integration doesn't works
lucatavola98
Platinum Partner
Hi everyone,
i read some posts and i have the same issue with the integration, i followed this guide https://www.3cx.it/doc/manuale/whatsapp/ step by step but doesn't works.
whatspp doesn't recognize my number as a account, so i can't receive any messages.
The guide is not updated with the last meta update.
Someone helps me please
Allego qui il problema che vedo quando arrivo al Passo4 della guida https://www.3cx.it/doc/manuale/whatsapp/. Provo ad assegnare al mio utente del sistema il token assegnando le risorse "whatsapp_business_messaging" e "whatsapp_business_management" ma mi da l'errore dell'immagine allegata.
Qualcuno per caso ha un contatto o qualcosa dove scrivere il problema a Meta?
Were you able to resolve this issue? Don’t hesitate to reach out if you need any assistance.
NortechTelecom
