When ever i tried to make a call it's not working?
mxm54908
New User
i follow the tutorial and my number provider is voip.ms so how can i make it work for outbound call?
08/15/2021 4:06:39 PM - Leg L:14.1[Extn:10] is terminated: Cause: BYE from PBX
08/15/2021 4:06:39 PM - [CM503020]: Call(C:14): Normal call termination. Call originator: Extn:10. Reason: Server Failure
08/15/2021 4:06:39 PM - L:14.1[Extn:10] failed to reach Line:10000>>14383785050, reason Server Failure
08/15/2021 4:06:39 PM - Leg L:14.2[Line:10000>>14383785050] is terminated: Cause: 503 Service Unavailable/INVITE from 192.175.96.73:5060
08/15/2021 4:06:39 PM - Call to T:Line:10000>>14383785050@[Dev:sip:[email protected]] from L:14.1[Extn:10] failed, cause: Cause: 503 Service Unavailable/INVITE from 192.175.96.73:5060
08/15/2021 4:06:39 PM - [CM503003]: Call(C:14): Call to <sip:[email protected]:0> has failed; Cause: 503 Service Unavailable/INVITE from 192.175.96.73:5060
08/15/2021 4:06:39 PM - [CM503025]: Call(C:14): Calling T:Line:10000>>14383785050@[Dev:sip:[email protected]] for L:14.1[Extn:10]
08/15/2021 4:06:39 PM - [CM503027]: Call(C:14): From: Extn:10 ("Maxime Marquette" <sip:[email protected]3cx.ca:0>) to T:Line:10000>>14383785050@[Dev:sip:[email protected]]
08/15/2021 4:06:39 PM - [CM503004]: Call(C:14): Route 1: from L:14.1[Extn:10] to T:Line:10000>>14383785050@[Dev:sip:[email protected]]
08/15/2021 4:06:39 PM - Line limit check: Current # of calls for line Lc:10000(@VoIP.MS[<sip:[email protected]:0/UDP>]) is 0; limit is 10
I see a lot of server errors there. Probably an issue with either VoIP.ms or your configuration.
Senergia
