Solved When using Webclient / Local App
jthornton
I've got machines using both the webclient, the 3CX native windows app and the Chrome version/smartapp (looks like a native app).
Is there a way to setup 3CX so that when the phone rings, all speakers ring, but when on a call, the earbuds are used?
Yes, on your webclient you can go to Settings > Audio/Video and change the output for the ringer and for speaker/microphone. I think the Windows app also works the same.
What version of 3CX PBX Are you running? v18?
Reactions: ChrisC_3CX
What @jpatel mentioned should also apply for the 3CX Desktop app. For the 3CX Windows App (formerly known as 3CX Phone for Windows), you have to click on "Settings >> Audio Options":
Thank you!
I was able to get it working if there are multiple sources for sound on a computer.
You're very welcome!
Glad we could help!
Bluebox Global
