Wifi Phones
Phil OE
Good Morning,
Are there any wifi enabled phones that will work with 3cx v 18 and going forward.
3CX doesn't support wireless connections, however we've used Yealink W phones over wireless if we had to. If you are setting it up as a router phone, do that while plugged in, then change to wireless. (also update the router phone firmware first otherwise it may trigger an IP block if you try with outdated firmware)
I was gonna buy the grandstream 810 and provision manually or try to.
Hi @Phil OE try to use the 3CX Mobile Apps or Dect Phones if they really need to go wireless, avoid using unsupported devices :)
Weve rolled out the Yealink T53W successfully.
Finatra.us
