Windows Client > Phone Communication
Chris A
Does the Windows Client need to communicate with the phones directly for any reason? I have both on separate VLANs/subnets. I am running into an issue when trying to use the Windows client to make a call on the phone it doesn't seem to do anything. The Windows client acts as if it is going to dial but doesn't & the actual phone does nothing. If it matters I am using a SNOM D717 phone.
The Windows client uses CTI, which does require the phone and PC to be able to communicate.
The Webclient, however, uses CSTA, which bypass this requirement.
Reactions: Chris A
Thanks for the clarification, do you know what port the Windows client uses to communicate with the phone in this manner?
Reactions: Chris A
gmacinit
