Windows to Debian Migration Fallback Plan
Yellow_Flash
We are planning to migrate our 3CX v20 installation from a windows server to a debian server, keeping the deployment at the same physical location.
The new debian server will use the same IP address and FQDN as the existing windows-based 3CX server.
To carry out the migration, we intend to shut down the windows server and then install 3CX on the debian server, configured with the same IP and FQDN.
However, our 3CX environment is integrated with multiple systems such as our CRM, which must function correctly after the migration.
Given this dependency, we want to ensure we have a fallback plan in case the debian server or related integrations do not work as expectd.
Our proposed fallback is to simply power down the Debian server and bring the Windows server back online with the original 3CX installation.
The question is, Is this fallback plan viable?
Specifically, can we revert to the windows-based 3CX server without requiring a fresh installation?
or would there be any issues related to licensing or FQDN/SSL that would prevent a seamless rollback?
Kindly, please provide your insights.
Thank you in advance.
There should not be any issue with this plan. I would simply advice not to make any big config changes to the new install before verifying all external services etc are working correctly, simply to avoid having to redo them in case you need to roll back.
The backup from your existing Windows install will be fully compatible with the Debian install and should bring over all CRM and such configs.
Unless you have made any unsupported changes such as installing 3rd party modules on Windows, it should be a smooth transition, and the fallback is very safe, it's an already active and working server, it will pick up from where you shut it down.
Best,
KS.
Best,
KS.
Thank you for the confirmation.
Appreciate the help @KyriacosS_3CX
Reactions: KyriacosS_3CX
x1515
