Wishes for more friendly 3CX Console
AWS2P
if 3CX DEV can increase how some console aspects works , this is not exhaustive , just few examples:
  1. Add ability to set time range in one shot for a week (not to have to do this day by day like for now)
  2. Add a way to modify time range without deleting existing one
  3. Add a button with delete file function everywhere file management is used in console (for audio files for holidays for example, for IVR....)
  4. Retablish IVR destination if no input within seconds to default value 0 instead of 1 to avoid unpleasant audio transitions with MOH starting for 1 second
  5. Retablish eye icon to reveal webclient password
Don't hesitate to add what you have in mind related to MC use.
Can you explain us how friendly it is to access audio files on linux cloud pbx? How easy login it is to have an overview of pbx folders, how friendly it is to remember password generated when pbx install was done , in which intuitive folders are located the files
Don't you think that these few points would justify a hundred times the presence of a button to delete files from MC quickly with no pain ?
On configure holidays settings what is the need to have past years in "is every year" field ?
[email protected].
