With 3cx app provisioned on Android phone Yealink desk extension does not ring
illcsales
3CX is16.0.612
Server Windows 10
On-premise dedicated server.
We can confirm a problem when app and yealink desk phone are assigned on same extension and app has been provisioned on android device.
The call is able to be answered on android device and does not ring desk phone.
We get Cause: 488 Not Acceptable Here/INVITE
Created test extension as requested with no desk phone and provisioned same android device with test extension.
We can call in and the desk phone is accessible through Digital assistant but DID fails.
We did try partialy availble here but that had no affect:
https://www.3cx.com/docs/android-app-faq/
So...was the desk phone working before the App extension was added, does it work if the App extension is removed or disabled? Are there other desk phone that work?
You said you created a test extension with no desk phone, then you say the desk phone is accessible though the IVR. Which desk set is this, as you said you did not create one in the test setup.
the fact that it is not reachable with a DID, may be another issue altogether.
All happened after the update to new version last week was working just fine before with app assigned... was hoping that the new version released this week would fix but it didn't...
It happens with app provisioned on extension and active remove and its just fine
3K8iMGWviZ
