Would be nice if the Web client included the hostname of the system
EscondidoAdmin
Enhancement request:
When you run the Web App, the text in the browser simply says "<section> - 3CX", here <section> reflects what part of the App you're in at the moment. For instance, when in the Admin Console, the browser tab says "Admin Console - 3CX." For admins who sometimes have multiple browser windows open in Admin Consoles, each in a different 3CX system, it would be of great help to include the system name at the beginning of the label. Example, we have 4 3CX instances. If I have a browser with 4 different tabs open, each in the Admin Console for a different system, If I want to view or make changes in a specific system, it's not readily apparent which tab is open to which system. Could the browser tab label say something like "Lab 3CX Admin Console" to make it easy to identify the system logged into is the Lab 3CX? This would make it easier to look at your display and see where the browser / tab is that you want to work in. Might get messy if the combined length of the system name and the rest of the text gets too long, otherwise the label will get truncated. Solution would be to put the system name first...
Example of a browser with 3 tabs, each in a different system - you have to cycle through and even then probably need to click around to find identifying information for which system you're in:
Thanks,
Upvote 3
