Yealink / 3CX / LDAP
David Hill
We have been testing the YeaLink T48S we are testing with 3CX, The YeaLink Device Management Platform is nice for pushing LDAD to the phones and I like how the Yealink handles the phone directory from AD better then 3CX pushes. My question is can you disable the LDAP push from 3CX and us the Yealink instead?
Hello David,
Just take a look at your parameter-settings. When you search for "ldap" you should get 4 parameters. Eventually theres a parameter for solving your problem. If not, reply to this and i will immediatly search for a Answer to solve your issue.
best regards,
Dominik Oelmaier
rmf
