Yealink bulk blf configure.
IHSupport
I am just wondering if there is a way of pushing out BLF config to all phones on the system rather than having to do one ext at a time?
i have played about with custom templates but that proved to be more hassle than what its worth.
Thanks for your time in advance.
Go to extensions and multi-click all of them with ctrl + click. You can then alter the BLFs from there. Obviously they will have the same BLF settings across the board so you may have to amend some individually after, but it gets you started.
Ensure they are a supported model on the correct firmware also.
Reactions: Dawn LaMothe
Something so simple but i just didn't think to try. Maybe they should add a button under the blf section to copy the settings to other ext's. just a thought.
thanks for the tip, it worked a charm.
I believe there is already a thread in the Ideas section you can upvote to help get this implemented.
cmedina
